Aller au contenu principal
Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement
Ce dont vous avez besoin
  1. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: étape 1, image 1 de 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: étape 1, image 2 de 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: étape 1, image 3 de 3
    • Complete this step to reduce the risk of burns, fire, electric shock, or injury.
    • Turn the control on the trimmers to "off".
    • Remove the plug from the electrical outlet.
  2. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: étape 2, image 1 de 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: étape 2, image 2 de 3 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: étape 2, image 3 de 3
    • Remove the two blade screws from the top blade of the trimmer.
  3. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: étape 3, image 1 de 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: étape 3, image 2 de 2
    • Lift the top blade from the device.
    • The bottom blade is attached, but not secured, to the underside of the top blade.
  4. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: étape 4, image 1 de 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: étape 4, image 2 de 2
    • Flip the top blade over.
    • Lift the bottom blade from the top blade.
  5. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: étape 5, image 1 de 2 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: étape 5, image 2 de 2
    • Clean or lubricate the device if necessary.
2 autres ont terminé cette réparation.
David Taylor
Membre depuis le 10/08/14
151 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 1-34, Donnelly Fall 2014 Membre de l'équipe USF Tampa, Team 1-34, Donnelly Fall 2014
USFT-DONNELLY-F14S1G34
1 membre
1 tutoriel rédigé
Un commentaire
Trying to find out how to sharpen. Blades are so expensive. $ 24 per pack.
I cut my hair every two weeks. Then dull blades.
I'd invest in some type of sharpening tool. ( Not sand paper ).
rslau13@gmail.com
Map daddy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 61
Total : 6,710
