Pièces
Aucune pièce nécessaire.
Use the screwdriver to pry off the stickers marked in red to reveal the location of 4 screws.
  • Use the screwdriver to pry off the stickers marked in red to reveal the location of 4 screws.
Ajouter un commentaire
Remove the 4 screws to continue.
  • Remove the 4 screws to continue.
Pry the center of the mouse apart to separate the upper and lower housing of the boards. Pry the center of the mouse apart to separate the upper and lower housing of the boards.
  • Pry the center of the mouse apart to separate the upper and lower housing of the boards.
Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
  • Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
  • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
Take the upper housing of the mouse and begin to remove the two screws (highlighted in red) that hold the board in place.
  • Take the upper housing of the mouse and begin to remove the two screws (highlighted in red) that hold the board in place.
Gently remove board.
  • Gently remove board.
The side buttons are the red push buttons highlighted in red. To remove them, flip the board over and desolder the leads highlighted in orange. Replace components with new ones and resolder back in place.
  • The side buttons are the red push buttons highlighted in red.
  • To remove them, flip the board over and desolder the leads highlighted in orange.
  • Replace components with new ones and resolder back in place.
Andreas Apitz
Membre depuis le 23/01/2014
116 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 1-39, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 5
Total : 344
