Introduction
This guide will help you re-seat or replace the IC chips on the computer's mother board. The IC chips, or Integrated Circuit chips, are used to perform various vital functions on the computer. Chips coming unseated or going bad is a common problem with the Apple II series and is easily fixed or replaced. Re-seating your chips will helpful if you are having trouble running your computer.
Pièces
Aucune pièce nécessaire.
Remove the six 19 mm long screws with a #2 Phillips head screwdriver. Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
Ajouter un commentaire
Release the catch by pushing it in using a plastic opening tool. The catch is off-center, but in line with the middle of the speaker underneath.
  • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove. Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
This step is wrong. The ports cover should be removed with a plastic disassembly tool first. Failure to do this will lead to a set of broken plastic hooks.
cybernesto - Réponse
Lift the handle straight up to remove. Lift the handle straight up to remove.
  • Lift the handle straight up to remove.
Tilt the keyboard up while detaching the ribbon connection by pulling it straight up.  You may have to wiggle the connector sideways to loosen it. Be careful not to force the ribbon while pulling it out to avoid tearing.  Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
  • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
  • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive. Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
  • Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally. Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally. Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally.
  • Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally.
Unscrew the four 8.5 mm screws that attach the floppy drive cage.  Two screws are located on the front and  back of the cage. Unscrew the four 8.5 mm screws that attach the floppy drive cage.  Two screws are located on the front and  back of the cage.
  • Unscrew the four 8.5 mm screws that attach the floppy drive cage. Two screws are located on the front and back of the cage.
There is actually no need to remove the cage in order to lift the floppy drive.
Carefully lift the floppy drive cage straight up to remove it. Carefully lift the floppy drive cage straight up to remove it.
  • Carefully lift the floppy drive cage straight up to remove it.
Lift the floppy drive straight up to remove. Lift the floppy drive straight up to remove.
  • Lift the floppy drive straight up to remove.
Use the plastic opening tools to carefully lever the IC chips out of the holder. Gently lever one end and then the other to lift it out of the chip holder. Do not force IC chips out! Pins are very fragile and can easily bend or break. Do not force IC chips out! Pins are very fragile and can easily bend or break.
  • Use the plastic opening tools to carefully lever the IC chips out of the holder. Gently lever one end and then the other to lift it out of the chip holder.
  • Do not force IC chips out! Pins are very fragile and can easily bend or break.
5 autre(s) ont terminé cette réparation.
Josiah
Membre depuis le 06/10/2011
508 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 21-23, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 40
Total : 4,610
