Introduction
This repair will need:
A T8 Torx screwdriver.
Pièces
Aucune pièce nécessaire.
After completing the initial disassembly, you may proceed to hard drive replacement.
  • After completing the initial disassembly, you may proceed to hard drive replacement.
Aubrey - Réponse
First, you will need to remove the five T8 torx screws that mount the hard drive to the internal frame. Next, you will remove the mounting frame and the plastic shield.
  • First, you will need to remove the five T8 torx screws that mount the hard drive to the internal frame.
  • Next, you will remove the mounting frame and the plastic shield.
Aubrey - Réponse
Aubrey - Réponse
You can use a spudger (tool shown in photo) to remove the ribbon cable from the hard drive.
  • You can use a spudger (tool shown in photo) to remove the ribbon cable from the hard drive.
Aubrey - Réponse
Carefully, pry the ribbon away from the pins.
  • Carefully, pry the ribbon away from the pins.
Aubrey - Réponse
Attach the ribbon cable to the new hard drive and follow steps 1-3, in reverse, to complete the installation.
  • Attach the ribbon cable to the new hard drive and follow steps 1-3, in reverse, to complete the installation.
Aubrey - Réponse
4 autre(s) ont terminé cette réparation.
Tyler
Membre depuis le 10/04/2011
129 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 20-66, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 20-66, Walters Spring 2011
CPSU-WALTERS-S11S20G66
4 membres
3 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 16
Total : 3,627
