Aller au contenu principal
Apple TV 3rd Generation Power Supply Replacement
Ce dont vous avez besoin
  1. Apple TV 3rd Generation Power Supply Replacement, Snap-on Base: étape 1, image 1 de 1
    • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
  2. Apple TV 3rd Generation Power Supply Replacement: étape 2, image 1 de 1
    • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
  3. Apple TV 3rd Generation Power Supply Replacement, Logic Board: étape 3, image 1 de 1
    • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
  4. Apple TV 3rd Generation Power Supply Replacement: étape 4, image 1 de 2 Apple TV 3rd Generation Power Supply Replacement: étape 4, image 2 de 2
    • Disconnect the power supply connector from the logic board with a spudger.
  5. Apple TV 3rd Generation Power Supply Replacement, Power Supply: étape 5, image 1 de 2 Apple TV 3rd Generation Power Supply Replacement, Power Supply: étape 5, image 2 de 2
    • Before you remove completely the power supply, unscrew the T5 screws on each side of the socket.
    • You may now be able to remove the power supply with a spudger.
    • The rating of the power supply is 3.4V at 1.75A, which is identical to the 2nd Gen Apple TV's 5.95 watts.
14 autres ont terminé cette réparation.
Vincent Monteil
Membre depuis le 07/06/13
6 975 Réputation
19 tutoriels rédigés
11 commentaires
you forgot to add the power supply is held by 2 tiny torx screw
morpheuse - Réponse
Successfully sourced a new power supply for our 3rd generation after the last one was destroyed ironically by Apple juice. Sourced from China and replaced- presto!! It's working- all for $14.95
rcbakes30 - Réponse
Where? I need on badly! Can you send me / Post here a link?
jakesterage -
please, and where could be find the part, the power supply for AppleTV 3rd generation?
foxy72 - Réponse
Hi, i have a 3rd gen Apple TV and I have problems with it, it doesn't turn on I don't now if it's the power supply or it is &&^&@@ up how can I figure out if it is the power supply and in that case where can I found one
ilichcorcegatreep - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 28
Total : 19,903
