Introduction
This is a replacement guide for the Apple iSight webcam privacy lens. It will demonstrate step-by-step how to disassemble the webcam in order to access the privacy lens.
Pièces
Aucune pièce nécessaire.
Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
  • Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
Ajouter un commentaire
Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
  • Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
Press the Apple logo through to pull apart the body frame from the body of the webcam. Press the Apple logo through to pull apart the body frame from the body of the webcam.
  • Press the Apple logo through to pull apart the body frame from the body of the webcam.
Remove the end cap with the Apple logo by simply pulling it off.
  • Remove the end cap with the Apple logo by simply pulling it off.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Unscrew the 3 (3.55 mm) screws surrounding the black casing near the camera-lens. Unscrew the 3 (3.55 mm) screws surrounding the black casing near the camera-lens.
  • Unscrew the 3 (3.55 mm) screws surrounding the black casing near the camera-lens.
Using tweezers, remove the netting that surrounds the black casing.
  • Using tweezers, remove the netting that surrounds the black casing.
Pry open the top of the black casing and pull it off.
  • Pry open the top of the black casing and pull it off.
    • There is slot on each side just below the power cord connector.
Unscrew 2 (4.41 mm) screws seen in the picture that surround the attachment of the lens to the main body.
  • Unscrew 2 (4.41 mm) screws seen in the picture that surround the attachment of the lens to the main body.
,Pull the loose circuit strip from its connection using tweezers. Do this for the side connection as well. This enables the entire camera lens section to come off.
  • ,Pull the loose circuit strip from its connection using tweezers.
  • Do this for the side connection as well. This enables the entire camera lens section to come off.
  • Pull the camera lens section off the main body.
Unscrew the final (4.41 mm) screw that connects the lens circuitry to the aperture. Then pull off the circuitry top section.
  • Unscrew the final (4.41 mm) screw that connects the lens circuitry to the aperture.
  • Then pull off the circuitry top section.
Pull off the top piece of the lens aperture. Finally, remove the privacy lens using tweezers.
  • Pull off the top piece of the lens aperture.
  • Finally, remove the privacy lens using tweezers.
Cullen Shorey
Membre depuis le 21/03/2018
157 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S5-G1, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S5-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G1
3 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 9
Total : 38
