Aller au contenu principal
Assembling Parabolic Solar Cooker Tripod Base Stand
Ce dont vous avez besoin
  1. Assembling Parabolic Solar Cooker Tripod Base Stand, Assembling Parabolic Solar Cooker Tripod Base Stand: étape 1, image 1 de 2 Assembling Parabolic Solar Cooker Tripod Base Stand, Assembling Parabolic Solar Cooker Tripod Base Stand: étape 1, image 2 de 2
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
  2. Assembling Parabolic Solar Cooker Tripod Base Stand: étape 2, image 1 de 1
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
To disassemble your device, follow these instructions in reverse order.
Ashlie Reott
Membre depuis le 10/20/13
340 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 4-30, Amido Fall 2013 Membre de l'équipe Cal Poly, Team 4-30, Amido Fall 2013
CPSU-AMIDO-F13S4G30
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 636
