Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Astro A50 Battery Replacement
Ce dont vous avez besoin
  1. Astro A50 Battery  Replacement, Battery: étape 1, image 1 de 3 Astro A50 Battery  Replacement, Battery: étape 1, image 2 de 3 Astro A50 Battery  Replacement, Battery: étape 1, image 3 de 3
    • To begin, remove the foam cushions from each earpiece by gently pulling the cushion away from the housing.
    • Use a small Phillips-head screwdriver to remove the 4 screws.
    Demander à FixBot
    Ajouter un commentaire
  2. Astro A50 Battery  Replacement: étape 2, image 1 de 3 Astro A50 Battery  Replacement: étape 2, image 2 de 3 Astro A50 Battery  Replacement: étape 2, image 3 de 3
    • Take extra care when removing objects that are glued down as they are subject to tear.
    • After setting aside the black plastic covers, use the screwdriver again to remove the two screws.
    • Identify the foam inner covers and peel back the upper corners of each foam to expose and remove the screws beneath.
    Demander à FixBot
  3. Astro A50 Battery  Replacement: étape 3, image 1 de 2 Astro A50 Battery  Replacement: étape 3, image 2 de 2
    • Gently fold aside the speaker assembly to expose the internals of the earpiece. Use caution to avoid damaging the black wires.
    • Remove the four screws marked in red to release the faceplate on the outside of the headset.
    Demander à FixBot
  4. Astro A50 Battery  Replacement: étape 4, image 1 de 2 Astro A50 Battery  Replacement: étape 4, image 2 de 2
    • Turn the earpiece over, and expose the battery by folding the microphone and cover plate away from the battery housing.
    • Desolder battery connections to disconnect the three colored wires from the old battery. Make note of corresponding colors/locations for installation of new battery.
    • Carefully remove the old battery by wedging a plastic opening tool or spudger underneath the battery to release the adhesive.
    • Do not bend or puncture the battery housing.
    Demander à FixBot
    • For reassembly, follow steps 1-4 in reverse order:
    • Take care to ensure battery wires are soldered correctly with each color on its corresponding pad.
    • Use minimal amounts of adhesive to re-attach the speaker foam to avoid glue making a mess.
    Demander à FixBot
Be sure to test your new battery to make sure the fix succeeded.
40 autres ont terminé cette réparation.
Nicholas Eriksen
Membre depuis le 10/28/15
987 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-5, Shastany Fall 2015 Membre de l'équipe UMass Dartmouth, Team 2-5, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G5
4 membres
10 tutoriels rédigés
33 commentaires de tutoriel
Could you post the dimensions of the battery itself? Seems like it's hard to find one that may or may not fit. That or could you recommend where to get a battery?
lolubad umad - Réponse Partager
i'd also like to know where to source the battery
drbob44 - Réponse Partager
Search for part no: 603443 on Ebay - ~$10 or buy one from Astro for $75
mattgorringe - Réponse Partager
So, which battery is the best replacement for the original? Is it possible to put some bigger batteries inside with some modding?
Rene Siekmann - Réponse Partager
Battery sizes are mAH, just by a 900 or more and that should do the trick. The actual size of the battery must be identical for a perfect fit and confortable headsets. Just make sure you get the correct voltage and size.
The battery comes with a cable, instead of soldering, can I tie those cables in? Also, what is the best way to remove and reattach foam cushions without damaging them?
cpaalvarez - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 32
30 derniers jours : 173
Total : 100,423
