Introduction
Are your keys not clicking? Did you spill any liquids on your keyboard recently? This guide will help you resolve these situations.
Use a metal spudger to pry off the two feet closest to the hinge of the laptop. The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals. The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
  • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
Ajouter un commentaire
Use a Phillips #0 screwdriver to unscrew the six 5mm screws. Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
  • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use a plastic opening tool to pry the keyboard off the edges of the computer. The edges will make a popping noise.
  • Use a plastic opening tool to pry the keyboard off the edges of the computer.
  • The edges will make a popping noise.
Flip up the white bar that connects the thin white strip using a plastic opening tool. Grab the thin white strip and pull straight back to remove the strip from the connector. Grab the thin white strip and pull straight back to remove the strip from the connector.
  • Flip up the white bar that connects the thin white strip using a plastic opening tool.
  • Grab the thin white strip and pull straight back to remove the strip from the connector.
Use a plastic opening tool to lift the black bar above the wide black strip in the connector. Grab the wide black strip and pull straight back to remove the strip from the connector. Remove the keyboard by lifting it straight up.
  • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
  • Grab the wide black strip and pull straight back to remove the strip from the connector.
  • Remove the keyboard by lifting it straight up.
Brittany M Won
Membre depuis le 18/04/2018
577 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S17-G4, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S17-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G4
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 61
