Introduction
Use this guide to replace or upgrade RAM in the Asus Eee PC 1005HA.
Loosen the captive screw in the RAM compartment cover. Remove the RAM compartment cover. This photo shows the battery still attached, but it should be removed prior to removing or replacing the RAM.
  • Loosen the captive screw in the RAM compartment cover.
  • Remove the RAM compartment cover.
  • This photo shows the battery still attached, but it should be removed prior to removing or replacing the RAM.
Ajouter un commentaire
Pull the two RAM retaining arms away from the center of the RAM chip. Gently pull the RAM chip out of its socket. Gently pull the RAM chip out of its socket.
  • Pull the two RAM retaining arms away from the center of the RAM chip.
  • Gently pull the RAM chip out of its socket.
7 autre(s) ont terminé cette réparation.
Mitchell Cesare
Membre depuis le 31/01/2012
705 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-22, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-22, Maness Winter 2012
CPSU-MANESS-W12S11G22
3 membres
6 tutoriels rédigés
Great guides. What is the maximum amount of RAM that this unit can accept?
MalikDon777 - Réponse
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 42
Total : 9,514
