Aller au contenu principal
Asus G73JH-RBBX05 Fan Replacement
Ce dont vous avez besoin
  1. Asus G73JH-RBBX05 Fan Replacement, Keyboard: étape 1, image 1 de 2 Asus G73JH-RBBX05 Fan Replacement, Keyboard: étape 1, image 2 de 2
    • Locate the 5 clips located at the top of the keyboard. Insert a metal spudger into the clip openings on the keyboard to remove the keyboard.
  2. Asus G73JH-RBBX05 Fan Replacement: étape 2, image 1 de 3 Asus G73JH-RBBX05 Fan Replacement: étape 2, image 2 de 3 Asus G73JH-RBBX05 Fan Replacement: étape 2, image 3 de 3
    • Before fully removing the keyboard, remove the back lighting cable and keyboard data strip.
    • In order to remove these cables, push forward the black retention clips and pull out the cables.
  3. Asus G73JH-RBBX05 Fan Replacement, Fan: étape 3, image 1 de 1
    • Remove the 4mm screws located under the keyboard with the PH0 screwdriver.
  4. Asus G73JH-RBBX05 Fan Replacement: étape 4, image 1 de 2 Asus G73JH-RBBX05 Fan Replacement: étape 4, image 2 de 2
    • Using a PH0 screwdriver, remove the two, 4mm screws .
    • Using either your finger or a plastic opening tool, remove the back panel.
  5. Asus G73JH-RBBX05 Fan Replacement: étape 5, image 1 de 1
    • Using the PH0 screwdriver, remove the nine, 4mm screws on the bottom of the laptop.
    • You must remove the two, 4mm screws located under the battery. Remove the battery by following these steps: Asus G73JH-RBBX05 Battery Replacement
  6. Asus G73JH-RBBX05 Fan Replacement: étape 6, image 1 de 1
    • Using a metal spudger, remove the back cover of the laptop.
    • Apply constant force in order to unhinged the panel.
  7. Asus G73JH-RBBX05 Fan Replacement: étape 7, image 1 de 2 Asus G73JH-RBBX05 Fan Replacement: étape 7, image 2 de 2
    • Remove the four, 4mm screws located on both of the hinges using the PH0 screwdriver and flip open the device.
    • Make sure you do this step for both the left and right hinges.
  8. Asus G73JH-RBBX05 Fan Replacement: étape 8, image 1 de 2 Asus G73JH-RBBX05 Fan Replacement: étape 8, image 2 de 2
    • Using a metal pry tool, remove the base cover
    • Once the cover is completely unhinged, don't forget to detach the strips connected to the motherboard.
  9. Asus G73JH-RBBX05 Fan Replacement: étape 9, image 1 de 3 Asus G73JH-RBBX05 Fan Replacement: étape 9, image 2 de 3 Asus G73JH-RBBX05 Fan Replacement: étape 9, image 3 de 3
    • Locate the fan and remove the three 2mm screws with the PH0 screwdriver.
    • Before removing the fan, disconnect the cable.
3 autres ont terminé cette réparation.
Trevor Sprosty
Membre depuis le 01/23/17
409 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 22-11, Maness Winter 2017 Membre de l'équipe Cal Poly, Team 22-11, Maness Winter 2017
CPSU-MANESS-W17S22G11
3 membres
5 tutoriels rédigés
Un commentaire
Some steps missing, regarding screws to remove: 1 screw that holds optical drive; once that is removed, 2 screws in the drive compartment; 2 screws in the battery compartment; 3 screws from the bottom of the motherboard.
Byron Canfield - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 12
Total : 1,605
