Aller au contenu principal
Asus Q534U RAM Replacement
Ce dont vous avez besoin
  1. Asus Q534U RAM Replacement, Back Case Removal: étape 1, image 1 de 1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U RAM Replacement: étape 2, image 1 de 2 Asus Q534U RAM Replacement: étape 2, image 2 de 2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U RAM Replacement: étape 3, image 1 de 2 Asus Q534U RAM Replacement: étape 3, image 2 de 2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U RAM Replacement: étape 4, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U RAM Replacement, RAM: étape 5, image 1 de 3 Asus Q534U RAM Replacement, RAM: étape 5, image 2 de 3 Asus Q534U RAM Replacement, RAM: étape 5, image 3 de 3
    • Locate the metal RAM cover
    • Pull the metal tab on the corner of the metal cover to lift the cover from its clips
    • A pry tool may provide a better grip on small tab.
  6. Asus Q534U RAM Replacement: étape 6, image 1 de 3 Asus Q534U RAM Replacement: étape 6, image 2 de 3 Asus Q534U RAM Replacement: étape 6, image 3 de 3
    • While pushing out the metal clips on both sides of the RAM, lift up the RAM to release it
    • Pull the RAM out gently and bring it up from the slot
    • Make sure to pull out first and then pull the RAM up out of place
5 autres ont terminé cette réparation.
Kyle Whalen
Membre depuis le 10/17/17
181 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S66-G6, Rockett Fall 2017 Membre de l'équipe UMass Dartmouth, Team S66-G6, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G6
3 membres
5 tutoriels rédigés
3 commentaires
One question: I have this model and have determined that I have a bad stick of RAM. I have removed this stick but still have 8 gigs available. Is there another stick that I m not seeing or is this built in?
Elijah Elliott - Réponse
saame here must be another stick somewhere
SvGGRK - Réponse
There are 4, 2GB chips of ram, hard built into the motherboard. Located right above the SSD m.2 bay, and beside the copper cooling line. This model of Laptop has one RAM bay, I'm not sure how the Built in and Bay RAM work together but for all intents and purposes, just assume you are only using the Bay for RAM. @svggrk @elijahelliott
Nirlicnick - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 35
Total : 6,861
