Make sure the device  is turned off and unplugged from  the charger.
  • Make sure the device is turned off and unplugged from the charger.
  • Using a T5 screwdriver, remove all 10 screws.
  • Pull off the back cover of the laptop.
  • A pry tool may be needed to pull off the back cover.
Ajouter un commentaire
Lift up the black tab next to the silver bridge. (seen on the right in the picture) Pull lightly on the blue tabs until the silver bridge is free.
  • Lift up the black tab next to the silver bridge. (seen on the right in the picture)
  • Pull lightly on the blue tabs until the silver bridge is free.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Using a Phillips #00 screwdriver, remove the 5 marked screws.
  • Using a Phillips #00 screwdriver, remove the 5 marked screws.
Locate the battery connector. Wedge a pry tool under the battery connector.
  • Locate the battery connector.
  • Wedge a pry tool under the battery connector.
  • Gently pull on the connector until the connector disconnects from the base of the object.
  • Pull out the battery.
Awesome step!
Mi Pa Si - Réponse
Disconnect the Wi-Fi antennae cables by gently detaching them with a pull in an upwards motion
  • Disconnect the Wi-Fi antennae cables by gently detaching them with a pull in an upwards motion
  • Needle nose pliers can be used as a detaching tool
Using a Phillips #0 screwdriver, remove the screw.
  • Using a Phillips #0 screwdriver, remove the screw.
  • Lift the Wi-Fi card out with an upward motion.
  • A prying tool can be used to lift the Wi-Fi card.
Eric Okoko
Membre depuis le 19/10/2017
227 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S66-G6, Rockett Fall 2017 Membre de l'équipe UMass Dartmouth, Team S66-G6, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G6
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 84
