Introduction
The motherboard is the most impotent part in the computer because most of the computer's parts are located on it or attached to it, so you will need to remove them in order to replace the motherboard. Watch out for some wires because they are hard to see.
Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 ,  two of them are 0.0793 JIS #0. Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 ,  two of them are 0.0793 JIS #0.
  • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
Ajouter un commentaire
Use the plastic opening tool to pry the back panel off the base of the laptop.
  • Use the plastic opening tool to pry the back panel off the base of the laptop.
Unscrew the four screws to remove the battery. Unscrew the four screws to remove the battery.
  • Unscrew the four screws to remove the battery.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Un-clip both wire clips on the upper and right side of the battery. Lift the battery out of the device.
  • Un-clip both wire clips on the upper and right side of the battery.
  • Lift the battery out of the device.
Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently. Watch out for the wires around the optical drive. Watch out for the wires around the optical drive.
  • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
  • Watch out for the wires around the optical drive.
Remove the fan by unscrewing the nine screws shown in the images. The four colored wire and the black cable need to be pulled out gently. There will be wires around the fan. Make sure they are not stuck to it.
  • Remove the fan by unscrewing the nine screws shown in the images.
  • The four colored wire and the black cable need to be pulled out gently.
  • There will be wires around the fan. Make sure they are not stuck to it.
  • You want to keep the fan if it still in good conditions.
Unscrew the  seven screws Phillips Head 0.0793 MM on the  edges of the motherboard. Unscrew the  seven screws Phillips Head 0.0793 MM on the  edges of the motherboard.
  • Unscrew the seven screws Phillips Head 0.0793 MM on the edges of the motherboard.
Disconnect any cables that hold the motherboard. Open up the white adjustable latch first to pull out the tapes. Open up the white adjustable latch first to pull out the tapes.
  • Disconnect any cables that hold the motherboard.
  • Open up the white adjustable latch first to pull out the tapes.
Baker
Membre depuis le 17/01/2018
248 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 29
Total : 65
