Aller au contenu principal
Asus ROG G53SW-XT1 Optical Drive Replacement
Ce dont vous avez besoin
  1. Asus ROG G53SW-XT1 Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Unplug the power cable and flip the computer over.
  2. Asus ROG G53SW-XT1 Optical Drive Replacement: étape 2, image 1 de 1
    • Unlock the battery by pushing the switch to the right.
  3. Asus ROG G53SW-XT1 Optical Drive Replacement: étape 3, image 1 de 2 Asus ROG G53SW-XT1 Optical Drive Replacement: étape 3, image 2 de 2
    • Push and hold the left switch, then pull the battery out.
  4. Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: étape 4, image 1 de 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: étape 4, image 2 de 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Keyboard: étape 4, image 3 de 3
    • Insert a spudger, or plastic opening tool, into these five slots and pry upwards to pop up the keyboard.
  5. Asus ROG G53SW-XT1 Optical Drive Replacement: étape 5, image 1 de 3 Asus ROG G53SW-XT1 Optical Drive Replacement: étape 5, image 2 de 3 Asus ROG G53SW-XT1 Optical Drive Replacement: étape 5, image 3 de 3
    • Disconnect the keyboard ribbon cables from the motherboard.
  6. Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: étape 6, image 1 de 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: étape 6, image 2 de 3 Asus ROG G53SW-XT1 Optical Drive Replacement, Back Panel: étape 6, image 3 de 3
    • Insert your screwdriver into the locking mechanism and slide it to the left. This will unlock the hand rest and allow you to pull it free.
  7. Asus ROG G53SW-XT1 Optical Drive Replacement: étape 7, image 1 de 1
    • Remove the fourteen Phillips #0 screws.
  8. Asus ROG G53SW-XT1 Optical Drive Replacement: étape 8, image 1 de 2 Asus ROG G53SW-XT1 Optical Drive Replacement: étape 8, image 2 de 2
    • Flip the laptop over and pull off the bottom cover.
  9. Asus ROG G53SW-XT1 Optical Drive Replacement, Optical Drive: étape 9, image 1 de 1
    • Remove the single 7mm Phillips #0 screw holding the hard drive in place.
  10. Asus ROG G53SW-XT1 Optical Drive Replacement: étape 10, image 1 de 2 Asus ROG G53SW-XT1 Optical Drive Replacement: étape 10, image 2 de 2
    • Slide the hard drive out of the casing.
Bailey Herring
Membre depuis le 02/21/18
393 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 4
Total : 220
