Introduction
This guide will show the user how to safely remove and replace the battery.
Lift the rubber cover found on the bottom of the laptop. Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
  • Lift the rubber cover found on the bottom of the laptop.
  • Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
Ajouter un commentaire
Use the nylon spudger to remove the back center panel. Use the nylon spudger to remove the back center panel. Use the nylon spudger to remove the back center panel.
  • Use the nylon spudger to remove the back center panel.
Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel. Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
  • Use a Phillips 1 Screwdriver to remove the 5 mm screw that is located underneath the back panel.
Pull out the optical drive found on the side of the laptop. Pull out the optical drive found on the side of the laptop.
  • Pull out the optical drive found on the side of the laptop.
Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop. Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
  • Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws. Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
  • Use a Phillips 1 Screwdriver to remove the top four 8.5 mm screws.
Use a nylon spudger to carefully pry the top back panel off. While removing the top back panel, be careful not to break the four pin connector located underneath. Disconnect the four-pin connector and remove the top back panel from the computer.
  • Use a nylon spudger to carefully pry the top back panel off.
  • While removing the top back panel, be careful not to break the four pin connector located underneath.
  • Disconnect the four-pin connector and remove the top back panel from the computer.
Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel. Lift away the metal housings from each side of the laptop. Lift away the metal housings from each side of the laptop.
  • Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
  • Lift away the metal housings from each side of the laptop.
Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place. Use a Phillips 1 Screwdriver to remove  the four 5.2 mm screws underneath the center panel.
  • Use a Phillips 1 Screwdriver to remove the ten 5.2 mm screws holding the main panel in place.
  • Use a Phillips 1 Screwdriver to remove the four 5.2 mm screws underneath the center panel.
Use a plastic opening tool to pry the keyboard from the base of the laptop. Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard. Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
  • Use a plastic opening tool to pry the keyboard from the base of the laptop.
  • Lift the keyboard carefully so as to not tear or break the four ribbon connectors underneath the keyboard.
Use a pair of tweezers to undo each of the four ribbon connectors. The keyboard is now completely disconnected from the laptop and you can remove it.
  • Use a pair of tweezers to undo each of the four ribbon connectors.
  • The keyboard is now completely disconnected from the laptop and you can remove it.
Use a pair of tweezers to carefully disconnect the pin connector. Use a pair of tweezers to carefully disconnect the pin connector.
  • Use a pair of tweezers to carefully disconnect the pin connector.
Use a Phillips 1 Screwdriver to remove the final four remaining 6.8 mm screws located underneath the back panel. The monitor is now free to be completely lifted off the laptop. The monitor is now free to be completely lifted off the laptop.
  • Use a Phillips 1 Screwdriver to remove the final four remaining 6.8 mm screws located underneath the back panel.
  • The monitor is now free to be completely lifted off the laptop.
Disconnect the pin connector that attaches the battery to the motherboard. Use a Phillips 1 Screwdriver to remove the two 5.4 mm screws.
  • Disconnect the pin connector that attaches the battery to the motherboard.
  • Use a Phillips 1 Screwdriver to remove the two 5.4 mm screws.
The battery can now be lifted away from the laptop. The battery can now be lifted away from the laptop.
  • The battery can now be lifted away from the laptop.
2 autre(s) ont terminé cette réparation.
Aurora Rios
Membre depuis le 22/01/2018
712 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S16-G1, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S16-G1, Banghart Winter 2018
CPSU-BANGHART-W18S16G1
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 41
Total : 96
