Introduction
This guide will teach you how to remove and replace the USB module in the event that it doesn't work properly. Special care must be taken, due to the delicate parts and ribbon cables needed to be removed during the repair.
Ce dont vous avez besoin
Flip the laptop over so the backside is facing upwards.
Using both hands, slide the lock mechanisms outwards and pull up to remove the battery.
Remove the nine 15.4mm Phillips #00 screws.
Remove the four 8.7mm Phillips #00 screws from the hard drive mounting bracket.
Remove the hard drive bracket.
Remove the two 2.8mm Phillips #00 screws.
Carefully remove the ZIF connector ribbon cable from the module by lifting up on the latch and pulling the cable out.
Un commentaire
Where do you find a replacement module? Does it have a specific product name?
