Aller au contenu principal
Asus Transformer T100 Front Facing Camera Board Replacement
Ce dont vous avez besoin
  1. Asus Transformer T100 Front Facing Camera Board Replacement, Rear Cover: étape 1, image 1 de 2 Asus Transformer T100 Front Facing Camera Board Replacement, Rear Cover: étape 1, image 2 de 2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Front Facing Camera Board Replacement: étape 2, image 1 de 2 Asus Transformer T100 Front Facing Camera Board Replacement: étape 2, image 2 de 2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
  3. Asus Transformer T100 Front Facing Camera Board Replacement: étape 3, image 1 de 1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Front Facing Camera Board Replacement: étape 4, image 1 de 2 Asus Transformer T100 Front Facing Camera Board Replacement: étape 4, image 2 de 2
    • Remove the rear casing.
  5. Asus Transformer T100 Front Facing Camera Board Replacement, Front Facing Camera Board: étape 5, image 1 de 1
    • The camera board is located in the red square in this image.
  6. Asus Transformer T100 Front Facing Camera Board Replacement: étape 6, image 1 de 2 Asus Transformer T100 Front Facing Camera Board Replacement: étape 6, image 2 de 2
    • Remove the two screws on the camera board using a Phillips #1 Screwdriver.
  7. Asus Transformer T100 Front Facing Camera Board Replacement: étape 7, image 1 de 3 Asus Transformer T100 Front Facing Camera Board Replacement: étape 7, image 2 de 3 Asus Transformer T100 Front Facing Camera Board Replacement: étape 7, image 3 de 3
    • Lift up the power button cable retention clip on the motherboard and pull the cable out.
  8. Asus Transformer T100 Front Facing Camera Board Replacement: étape 8, image 1 de 2 Asus Transformer T100 Front Facing Camera Board Replacement: étape 8, image 2 de 2
    • On the camera connection apparatus, locate the silver tape that connects to the tablet.
    • Peel the silver tape off of the tablet on both sides of the connection apparatus.
    • If this step has been completed correctly, the camera board should be loose, with the tape still attached to the connection apparatus.
  9. Asus Transformer T100 Front Facing Camera Board Replacement: étape 9, image 1 de 3 Asus Transformer T100 Front Facing Camera Board Replacement: étape 9, image 2 de 3 Asus Transformer T100 Front Facing Camera Board Replacement: étape 9, image 3 de 3
    • Gently pull the Orange ribbon cable out of the connection port.
    • This port has no clip. The orange apparatus should slide out with a small tug.
2 autres ont terminé cette réparation.
Taylor Pantiga
Membre depuis le 04/14/14
1 596 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 13-31, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 membres
6 tutoriels rédigés
Un commentaire
Hello, can you please tell a manufacturer of the camera (is it writter somethere on it)?
Alexius Hoopakele Ae - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 4
Total : 3,658
