Aller au contenu principal
Asus V6800V CD/DVD Drive Replacement
Ce dont vous avez besoin
  1. Asus V6800V CD/DVD Drive Replacement, Battery: étape 1, image 1 de 2 Asus V6800V CD/DVD Drive Replacement, Battery: étape 1, image 2 de 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V CD/DVD Drive Replacement, Hard Drive: étape 2, image 1 de 2 Asus V6800V CD/DVD Drive Replacement, Hard Drive: étape 2, image 2 de 2
    • Remove the two screws using a Phillips #0 screwdriver.
  3. Asus V6800V CD/DVD Drive Replacement: étape 3, image 1 de 2 Asus V6800V CD/DVD Drive Replacement: étape 3, image 2 de 2
    • Pry open the case using an iFixit opening tool.
    • Actual hard drive is not shown in the second image.
  4. Asus V6800V CD/DVD Drive Replacement: étape 4, image 1 de 2 Asus V6800V CD/DVD Drive Replacement: étape 4, image 2 de 2
    • The highlighted area is where your hard drive would be. Slide it out away from its slot and pull it gently to remove.
    • Second image shows what it should look like once you remove the hard drive.
  5. Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: étape 5, image 1 de 2 Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: étape 5, image 2 de 2
    • Remove the screw from the bottom right corner using a Phillips #0 screwdriver.
    • Insert a spudger into the hole to carefully push the CD/DVD drive out.
To reassemble your device, just push the new CD/DVD driver back. Then put the components back together then put the screws back in.
Jong Park
Membre depuis le 06/24/10
114 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 2-9, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 4,259
