Introduction
Fan is a very essential part of a laptop which prevents it from overheating. Your Asus V6800V Fan needs to be changed when your laptop is running slow due to overheating or the fan is making a usual noisy sound or in some cases the fan stops immediately after starting. Before changing your Asus V6800V Fan use this page to confirm that the problem is actually in the fan but not any other parts.
The replacement guide will help you change your Asus V6800V Fan in the following simple steps. It won’t take more than 30 minutes.
Ce dont vous avez besoin
Place the computer upside down.
Using your thumbs, slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
Use the Phillips #0 to remove the six screws on the back of the device.
Gently open the cover using the tab located by the highlighted box.
