Flip the computer over so that it is upside down. Slide both latches away from each other (towards the outside).
  • Flip the computer over so that it is upside down.
  • Slide both latches away from each other (towards the outside).
  • Push the battery out with your fingers.
  • The actual battery is not shown in the photograph.
Ajouter un commentaire
On the back panel unscrew highlighted screws and carefully put them to the side as not to lose them.
  • On the back panel unscrew highlighted screws and carefully put them to the side as not to lose them.
Locate the RAM chip highlighted in Blue and the two metal tabs holding it in place highlighted in red.
  • Locate the RAM chip highlighted in Blue and the two metal tabs holding it in place highlighted in red.
Carefully use your thumbs to push out the metal tabs and the RAM should spring up.
  • Carefully use your thumbs to push out the metal tabs and the RAM should spring up.
After the ram has sprung up, carefully grab the edges with your fingers and gently pull straight out.
  • After the ram has sprung up, carefully grab the edges with your fingers and gently pull straight out.
After you have gotten either more RAM or replacement RAM line up the pins and slot (highlighted red) in the RAM card with the pin on the computer.
  • After you have gotten either more RAM or replacement RAM line up the pins and slot (highlighted red) in the RAM card with the pin on the computer.
  • Carefully insert the new ram in at the same angle that you removed it at.
  • The other side of the RAM slot is a place for more RAM if you want to put more in. The spaces are highlighted in blue.
Connor
Membre depuis le 24/06/2010
36 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 2-9, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 membres
11 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 3,118
