Aller au contenu principal
Asus VivoBook Q200E-BSI3T08 Trackpad Replacement
Ce dont vous avez besoin
  1. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Back Panel: étape 1, image 1 de 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: étape 2, image 1 de 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: étape 3, image 1 de 2 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: étape 3, image 2 de 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Battery: étape 4, image 1 de 1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: étape 5, image 1 de 3 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: étape 5, image 2 de 3 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: étape 5, image 3 de 3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: étape 6, image 1 de 2 Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: étape 6, image 2 de 2
    • Now just lift the battery out of place.
  7. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement, Trackpad: étape 7, image 1 de 1
    • Disconnect the small blue TP(trackpad) labeled data bus.
  8. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: étape 8, image 1 de 1
    • Identify the ten 2.94mm screws on the metal bracket.
  9. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: étape 9, image 1 de 1
    • Unscrew the ten 2.94mm screws with the Philips #00 Head.
  10. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: étape 10, image 1 de 1
    • Remove all of the metallic tape holding the metal bracket to the components surrounding it.
  11. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: étape 11, image 1 de 1
    • Lift the metal bracket away from the laptop.
  12. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: étape 12, image 1 de 1
    • Unscrew the four 3.5mm screws with Phillips #00 Head.
    • This black plastic panel holds the trackpad in place.
  13. Asus VivoBook Q200E-BSI3T08 Trackpad Replacement: étape 13, image 1 de 1
    • Lift the trackpad up from the laptop and slide it out of the housing.
Mitchell Jackson
Membre depuis le 05/17/17
742 Réputation
7 tutoriels rédigés
Équipe
IUPUI, Team S4-G4, Wilson Summer 2017 Membre de l'équipe IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 9
Total : 567
