Introduction
The 2-in-1 touchscreen display can become unresponsive or cracked due to it being used often. If the display gets damaged or becomes unresponsive, and you determine it is not a power issue, the guide shows how to replace the entire display.
Pièces
Aucune pièce nécessaire.
Before doing a repair or replacement make sure the laptop is fully shut off. Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
  • Before doing a repair or replacement make sure the laptop is fully shut off.
  • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
Ajouter un commentaire
Insert the flat edge of the opening tool in between the back casing to remove the back casing. Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  • Insert the flat edge of the opening tool in between the back casing to remove the back casing.
  • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
Using the JIS #0 Screwdriver, remove the five 3.0 mm screws that hold down the hard drive casing. Using the JIS #0 Screwdriver, remove the five 3.0 mm screws that hold down the hard drive casing.
  • Using the JIS #0 Screwdriver, remove the five 3.0 mm screws that hold down the hard drive casing.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Lift the hard drive up and remove the power supply cable connected to it. Make sure to pull on the plastic head and not the actual wires to prevent tearing them. Make sure to pull on the plastic head and not the actual wires to prevent tearing them.
  • Lift the hard drive up and remove the power supply cable connected to it.
  • Make sure to pull on the plastic head and not the actual wires to prevent tearing them.
Disconnect the white and black wires attached to the Wi-Fi chip. Disconnect the white and black wires attached to the Wi-Fi chip.
  • Disconnect the white and black wires attached to the Wi-Fi chip.
Remove the two adapters connecting the display to the motherboard by pulling the black plastic straps directly upwards. Remove the two adapters connecting the display to the motherboard by pulling the black plastic straps directly upwards. Remove the two adapters connecting the display to the motherboard by pulling the black plastic straps directly upwards.
  • Remove the two adapters connecting the display to the motherboard by pulling the black plastic straps directly upwards.
Use the JIS #0 screwdriver to remove the five 5.0 mm screws connecting the display to the rest of the laptop. Use the JIS #0 screwdriver to remove the five 5.0 mm screws connecting the display to the rest of the laptop. Use the JIS #0 screwdriver to remove the five 5.0 mm screws connecting the display to the rest of the laptop.
  • Use the JIS #0 screwdriver to remove the five 5.0 mm screws connecting the display to the rest of the laptop.
Deric Wright
Membre depuis le 14/02/2018
573 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S5-G5, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 39
