Introduction
The fan maintains the processor in its operating temperature. Dust buildup is common so it is essential to clean the fan occasionally. In extreme cases, the entire fan and heat sink assembly can be replaced.
Pièces
Aucune pièce nécessaire.
Before doing a repair or replacement make sure the laptop is fully shut off. Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place.
  • Before doing a repair or replacement make sure the laptop is fully shut off.
  • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Pry open the back casing using the opening tool along the side crevice. Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  • Pry open the back casing using the opening tool along the side crevice.
  • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
Remove the following screws that mount the fan and heatsink to the motherboard: Three 3.0 mm screws for the fan Four 2.0  mm screws for the heatsink
  • Remove the following screws that mount the fan and heatsink to the motherboard:
  • Three 3.0 mm screws for the fan
  • Four 2.0 mm screws for the heatsink
  • The bottom of the heatsink will contain thermal paste. Avoid making contact with this as any dirt or oils can reduce the effectiveness of the cooler.
Carl Zuehlsdorf
Membre depuis le 13/02/2018
98 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S5-G5, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 33
