Aller au contenu principal
Asus VivoTab RT TF600T LCD Screen Replacement
Ce dont vous avez besoin
  1. Asus VivoTab RT TF600T LCD Screen  Replacement, LCD Screen: étape 1, image 1 de 3 Asus VivoTab RT TF600T LCD Screen  Replacement, LCD Screen: étape 1, image 2 de 3 Asus VivoTab RT TF600T LCD Screen  Replacement, LCD Screen: étape 1, image 3 de 3
    • Make sure the tablet is turned off.
    • Remove the tablet from the attached keyboard.
    • To remove the keyboard, simply depress the switch on the left side of the screen and pull the tablet portion off.
  2. Asus VivoTab RT TF600T LCD Screen  Replacement: étape 2, image 1 de 3 Asus VivoTab RT TF600T LCD Screen  Replacement: étape 2, image 2 de 3 Asus VivoTab RT TF600T LCD Screen  Replacement: étape 2, image 3 de 3
    • Rotate the device 180°, and remove the two 1.59 mm screws at the bottom of the device.
    • Use the Phillips screwdriver size #000 to remove the two 1.59 mm screws.
  3. Asus VivoTab RT TF600T LCD Screen  Replacement: étape 3, image 1 de 2 Asus VivoTab RT TF600T LCD Screen  Replacement: étape 3, image 2 de 2
    • Use the plastic opening tool to help detach the screen from the back panel.
    • Insert the plastic opening tool into the bottom right corner and gently start to pry off the screen.
    • Once the screen begins to separate from the body of the device, start working the tool around the outer edges until the entire screen becomes detached.
  4. Asus VivoTab RT TF600T LCD Screen  Replacement: étape 4, image 1 de 2 Asus VivoTab RT TF600T LCD Screen  Replacement: étape 4, image 2 de 2
    • Now that the screen is completely detached, lay the back panel flat on a smooth surface.
    • Lift the screen to view the inside of the tablet.
  5. Asus VivoTab RT TF600T LCD Screen  Replacement: étape 5, image 1 de 2 Asus VivoTab RT TF600T LCD Screen  Replacement: étape 5, image 2 de 2
    • Before disconnecting the display cables, refer to the image to turn off the switch labeled DIP; this switch is used to de-energize the system.
    • The battery is connected to the motherboard. To avoid any short circuiting of the device, you must place the switch labeled DIP to OFF.
  6. Asus VivoTab RT TF600T LCD Screen  Replacement: étape 6, image 1 de 3 Asus VivoTab RT TF600T LCD Screen  Replacement: étape 6, image 2 de 3 Asus VivoTab RT TF600T LCD Screen  Replacement: étape 6, image 3 de 3
    • Remove the yellow tape covering the end of the cables.
  7. Asus VivoTab RT TF600T LCD Screen  Replacement: étape 7, image 1 de 2 Asus VivoTab RT TF600T LCD Screen  Replacement: étape 7, image 2 de 2
    • After lifting the yellow tape, you should be able to see a white strip. The white strip is actually a lever.
    • Use the plastic opening tool to push in the levers.
  8. Asus VivoTab RT TF600T LCD Screen  Replacement: étape 8, image 1 de 3 Asus VivoTab RT TF600T LCD Screen  Replacement: étape 8, image 2 de 3 Asus VivoTab RT TF600T LCD Screen  Replacement: étape 8, image 3 de 3
    • With all three white levers pushed in, gently pull on each display cable until the cable disconnects.
  9. Asus VivoTab RT TF600T LCD Screen  Replacement: étape 9, image 1 de 1
    • Lift the screen upwards to remove.
Congratulations! You have now successfully removed the screen from your device. To attach your new screen and reassemble your device follow these instructions in reverse order.
5 autres ont terminé cette réparation.
Brittany
Membre depuis le 10/13/15
490 Réputation
2 tutoriels rédigés
Équipe
Sam Houston State, Team 1-2, Blackburne Fall 2015 Membre de l'équipe Sam Houston State, Team 1-2, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 12
Total : 3,212
