Introduction
Remove the disc drive on your Asus W2W-A1 so that you may replace it with a new disc drive or a stick a hard drive in its place.
Pièces
Aucune pièce nécessaire.
Use a Phillips head screwdriver to remove the one 3mm screw labeled D on the back of the laptop.
  • Use a Phillips head screwdriver to remove the one 3mm screw labeled D on the back of the laptop.
Ajouter un commentaire
With that screw removed, you can now pull the disc drive out of the laptop by pulling on it in the direction that it slides. With that screw removed, you can now pull the disc drive out of the laptop by pulling on it in the direction that it slides.
  • With that screw removed, you can now pull the disc drive out of the laptop by pulling on it in the direction that it slides.
Emily Mullins
Membre depuis le 14/04/2014
201 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 13-29, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 183
