Pièces
Aucune pièce nécessaire.
Using the Phillips 1 screwdriver, remove the laptop's back panel.
  • Using the Phillips 1 screwdriver, remove the laptop's back panel.
  • The parts you see underneath that panel are called the laptop's "internals".
Ajouter un commentaire
The fan will be visible toward the bottom of the internals. It  is semicircular with a small wire connected to the top of it.
  • The fan will be visible toward the bottom of the internals. It is semicircular with a small wire connected to the top of it.
  • Visually inspect the fan for any debris or blockage. If there is none, the fan probably needs to be replaced. To do that, we need to first disconnect the fan from the computer.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Disconnect the fan by gently pulling the connectors on the wire apart from each other.
  • Disconnect the fan by gently pulling the connectors on the wire apart from each other.
Now, use the Phillips 1 screwdriver to unfasten the two screws holding the fan in place.
  • Now, use the Phillips 1 screwdriver to unfasten the two screws holding the fan in place.
  • From here, the fan will lift easily out of the laptop.
Samantha Wahl
Membre depuis le 17/10/2017
301 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 Membre de l'équipe UMass Dartmouth, Team S1-G2, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G2
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 41
