Aller au contenu principal
Asus X200CA-HCL 1104G Headphone Jack Replacement
Ce dont vous avez besoin
  1. Asus X200CA-HCL 1104G Headphone Jack Replacement, Headphone Jack: étape 1, image 1 de 1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Headphone Jack Replacement: étape 2, image 1 de 1
    • Now, locate the audio board. This model has an L-shaped board. It can be found in the far left region of the internals.
  3. Asus X200CA-HCL 1104G Headphone Jack Replacement: étape 3, image 1 de 1
    • Firstly, disconnect the two tiny wires that connect the audio board to other components. They can be found on a black square near the green decoder strip. Remember to be gentle with these delicate components.
  4. Asus X200CA-HCL 1104G Headphone Jack Replacement: étape 4, image 1 de 2 Asus X200CA-HCL 1104G Headphone Jack Replacement: étape 4, image 2 de 2
    • Using the Phillips 1 screwdriver, remove the six screws that hold the audio board in place.
    • Hint: the sixth screw may not be readily visible. It can be found in the bottom left corner of the audio board, under a small black flap.
    • With the screws removed, the audio board can be easily lifted out.
Samantha Wahl
Membre depuis le 10/17/17
301 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G2, Simcock Fall 2017 Membre de l'équipe UMass Dartmouth, Team S1-G2, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 8
Total : 122
