Aller au contenu principal
Asus X200MA Hard Drive Replacement
Ce dont vous avez besoin
  1. Asus X200MA Hard Drive Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Hard Drive Replacement: étape 2, image 1 de 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  3. Asus X200MA Hard Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • Remove the black foam and adhesive located on top of the hard drive.
  4. Asus X200MA Hard Drive Replacement: étape 4, image 1 de 1
    • Remove the following four screws:
    • Four 4 mm Phillips #0 using a phillips screwdriver.
  5. Asus X200MA Hard Drive Replacement: étape 5, image 1 de 1
    • Slide out the hard drive
3 autres ont terminé cette réparation.
Vanessa Garcia
Membre depuis le 01/22/15
1 763 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 21-24, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 membres
8 tutoriels rédigés
2 commentaires
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
Matthew Miller - Réponse
Very poor!!! If you follow this instruction, you will destroy your Laptop. I did nearly destroying it. You did not show the 2 screws under the rubbers.
Minus 1000 points!!!
luft_ha - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 11
Total : 9,285
