Introduction
The Asus X551CA power button allows the laptop to turn on and off. If it is broken, the laptop will not receive the signal to boot up.
Ce dont vous avez besoin
Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
Two 4.3 mm screws in the back corners
One 17.5 mm screw at the left edge near the optical drive
Three 4.3 mm screws in the front edge
Locate the power button in the corner of the keyboard plate cover.
Disconnect the ribbon from the small green board by flipping up the small white flap and pulling parallel to the green board's surface.
7 autres ont terminé cette réparation.
