Aller au contenu principal
Asus Z54C-JS31 WiFi Card Replacement
Ce dont vous avez besoin
  1. Asus Z54C-JS31 WiFi Card Replacement, Battery: étape 1, image 1 de 3 Asus Z54C-JS31 WiFi Card Replacement, Battery: étape 1, image 2 de 3 Asus Z54C-JS31 WiFi Card Replacement, Battery: étape 1, image 3 de 3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 WiFi Card Replacement, HDD/RAM Cover Panel: étape 2, image 1 de 2 Asus Z54C-JS31 WiFi Card Replacement, HDD/RAM Cover Panel: étape 2, image 2 de 2
    • Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
  3. Asus Z54C-JS31 WiFi Card Replacement: étape 3, image 1 de 2 Asus Z54C-JS31 WiFi Card Replacement: étape 3, image 2 de 2
    • Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
  4. Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: étape 4, image 1 de 3 Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: étape 4, image 2 de 3 Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: étape 4, image 3 de 3
    • Disconnect both the black and white coaxial connectors from the WiFi card by pulling up on the gold colored piece.
  5. Asus Z54C-JS31 WiFi Card Replacement: étape 5, image 1 de 3 Asus Z54C-JS31 WiFi Card Replacement: étape 5, image 2 de 3 Asus Z54C-JS31 WiFi Card Replacement: étape 5, image 3 de 3
    • Remove the 3mm screw from the top right corner of the WiFi card using a Phillips #0 screwdriver.
    • The WiFi card will pop up. Grasp it and pull it out of its slot.
Mark DeSimone
Membre depuis le 10/19/17
801 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G1, Bailey Fall 2017
UMASSD-BAILEY-F17S3G1
2 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,414
