Introduction
One of the most common issues with the Atari 5200 is faulty controller wiring- a controller's buttons will become unresponsive, hard to press, or even stuck in place. This guide will cover replacing the entire circuit board for the buttons, reseating each button to ensure proper contact and operation of each button.
Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws. Carefully slide and pull the two parts of the controller shell apart, exposing the innards. Try not to move the joystick when reassembling. This will almost assuredly break your alignment. The less the joystick is moved, the easier it will be to realign the joystick to the pots.
  • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
  • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
  • Try not to move the joystick when reassembling. This will almost assuredly break your alignment. The less the joystick is moved, the easier it will be to realign the joystick to the pots.
Ajouter un commentaire
Slide out the strip of the board connected to the controller's START, PAUSE, and RESET buttons. Slide out the strip of the board connected to the controller's START, PAUSE, and RESET buttons. Slide out the strip of the board connected to the controller's START, PAUSE, and RESET buttons.
  • Slide out the strip of the board connected to the controller's START, PAUSE, and RESET buttons.
Peel off the old circuit board. The buttons should fall out/be removable. Disconnect it from the wire connector.
  • Peel off the old circuit board.
  • The buttons should fall out/be removable.
  • Disconnect it from the wire connector.
Place the new circuit board where the old one was. Glue/tape it in places where the previous board was held. Connect it to the wire connector.
  • Place the new circuit board where the old one was.
  • Glue/tape it in places where the previous board was held.
  • Connect it to the wire connector.
Use a spudger to remove the top frame. Take off the plate.
  • Use a spudger to remove the top frame.
  • Take off the plate.
  • Remove the rubber buttons.
Pull the circuit strip through the new space. Realign the top and bottom of the controller.
  • Pull the circuit strip through the new space.
  • Realign the top and bottom of the controller.
Return the buttons to the top of the controller. Snap the frame back into place. Screw the Screws
  • Return the buttons to the top of the controller.
  • Snap the frame back into place.
  • Screw the Screws
Ligne d'arrivée
Zach Petryszyn
Membre depuis le 26/09/2014
15 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 13-1, Staggers Fall 2014 Membre de l'équipe USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 21
Total : 1,526
