Introduction
Do not forget to eject the navigation CD-ROM before you disconnect the unit.
This guide does not show you how to remove the unit from the car.
This guide contains the least amount of steps to clean the lens. In case you drop the white plastic disk that holds the CD-ROM down (step 2), you have to take apart the unit.
Follow this guide in case that has happened to you.
Ce dont vous avez besoin
Use the flat edge of a metal spudger and/or a flat head screwdriver to pry open the top cover.
When closing the cover, make sure the cover is completely locked as shown in the third picture.
It is advisable to grab an old CD and push it half way into the CD-ROM drive until it is visible through the hole marked in the first picture. This will prevent the part that has to be removed in this step to fall down into the unit, with the risk of damaging the laser.
The metal plate slides forward as shown in the first picture.
Locate the lens inside the CD-ROM drive.
Dip one end of a cotton swab in rubbing alcohol.
Lightly dab the swab on the lens. Be very gentle.
Let the lens dry before putting the unit back together.
7 autres ont terminé cette réparation.
Un commentaire
Hi, Michael. Maybe it's too late, but:
1. Yes, the screw was very tight. I unfastened it like with an impact screwdriver: simultaneously pressed down and turned. Only a quality tool will do the job
2. When You remove the screw and the spring You can detach the white plastic ring. At that moment You need a CD to prevent the ring falling down
3. After You have tied the ring You can remove the CD and lower the ring inside the unit to gain access to the lens
4. Yes, the CD-ROM reads original disks without problem
Sorry for my english, also. TI hope that helps
