Introduction
This guide will help your install a new driver.
Remove the ear pads by peeling them away from the grill.
  • Remove the ear pads by peeling them away from the grill.
Ajouter un commentaire
Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
Remove the speaker from the grill by pulling it out.
  • Remove the speaker from the grill by pulling it out.
  • Remove the speaker carefully so you do not rip the wires out.
With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
  • With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
Pull the driver out of its bracket.
  • Pull the driver out of its bracket.
Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference Comment souder et dessouder des connexions. The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
  • Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference Comment souder et dessouder des connexions.
  • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
Connect the existing wires to the new driver by re-soldering the wires using the soldering iron. Using the copper as a reference, re-solder the yellow wire to the top left solder joint and the red to the bottom left solder joint.
  • Connect the existing wires to the new driver by re-soldering the wires using the soldering iron.
  • Using the copper as a reference, re-solder the yellow wire to the top left solder joint and the red to the bottom left solder joint.
Nick Levy
Membre depuis le 13/01/2013
106 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-19, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 membres
6 tutoriels rédigés
where can i buy a replacement driver?
acidxgangster - Réponse
You can order parts directly from PARTS@ATUS.COM
Nick Levy -
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 35
30 derniers jours : 128
Total : 4,928
