Introduction
This repair guide will help you with the following:
  • Install the left headphone cable
  • Fix sound coming from the left headphone
Remove the ear pads by peeling them away from the grill.
  • Remove the ear pads by peeling them away from the grill.
Ajouter un commentaire
Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
Remove the speaker from the grill by pulling it out.
  • Remove the speaker from the grill by pulling it out.
  • Remove the speaker carefully so you do not rip the wires out.
Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference Comment souder et dessouder des connexions. The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again. The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again.
  • Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference Comment souder et dessouder des connexions.
  • The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again.
Untie the knot in the thick main cable. Remove the main cable from the headphones by pulling it out.
  • Untie the knot in the thick main cable.
  • Remove the main cable from the headphones by pulling it out.
  • Thread the replacement cable into the hole on the bottom of the headphones. Pull the cable all the way through.
Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference Comment souder et dessouder des connexions. The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again. The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
  • Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference Comment souder et dessouder des connexions.
  • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
Melanie Reis
Membre depuis le 11/01/2013
106 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 17-19, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 membres
6 tutoriels rédigés
Thank you so much! your guide helped me repair my AD900x!
Anwar X - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 17
30 derniers jours : 86
Total : 3,992
