Introduction
This guide will help teach you how to remove and replace the drum of the gun that holds your darts. This require splitting the gun into two halves and requires a #00 Phillips head screwdriver, but is otherwise fairly simple. Just follow the steps and get your gun back into fighting shape!
Pièces
Aucune pièce nécessaire.
Locate the orange slider on the front side of the gun. Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  • Locate the orange slider on the front side of the gun.
  • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
Ajouter un commentaire
Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver. Remove all parts within the chamber to be able to completely detach the nose of the gun. Be careful to keep track of all the components for reassembly.
  • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
  • Remove all parts within the chamber to be able to completely detach the nose of the gun.
  • Be careful to keep track of all the components for reassembly.
Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left. Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left. Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
  • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
  • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
Carefully spread apart the two halves of the gun, and lift out the ammo drum.
  • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
2 autre(s) ont terminé cette réparation.
Moira Foster
Membre depuis le 09/10/2014
377 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-22, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 221
