Aller au contenu principal
BEM Mojo 2 Charging Base Battery Replacement
Ce dont vous avez besoin
  1. BEM Mojo 2 Charging Base Battery Replacement, Charging Base Battery: étape 1, image 1 de 1
    • Use the metal spudger to peel back the rubber from the bottom of the auxiliary charging base to reveal the screw.
  2. BEM Mojo 2 Charging Base Battery Replacement: étape 2, image 1 de 1
    • Use the screwdriver with the J0 bit attatched to detach all four 10 mm screws from the charging base.
  3. BEM Mojo 2 Charging Base Battery Replacement: étape 3, image 1 de 2 BEM Mojo 2 Charging Base Battery Replacement: étape 3, image 2 de 2
    • Pull the top cover off of the charging base to reveal the internal chip.
    • Use the plastic opening tool to pry the battery from the top cover.
    • Caution: Be careful when detaching battery from top cover as to not damage any of the wires attached to it.
  4. BEM Mojo 2 Charging Base Battery Replacement: étape 4, image 1 de 1
    • Use the tweezers to carefully detach the wires from the internal chip.
    • Caution: Be careful to not damage the internal chip when removing the wires.
Rachel Iacoboni
Membre depuis le 01/30/18
618 Réputation
5 tutoriels rédigés
Équipe
Baylor, Team S1-G1, Johnson Spring 2018 Membre de l'équipe Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 391
