Aller au contenu principal
BEM Mojo 2 Speaker Battery Replacement
Ce dont vous avez besoin
  1. BEM Mojo 2 Speaker Battery Replacement, Speaker Battery: étape 1, image 1 de 1
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
  2. BEM Mojo 2 Speaker Battery Replacement: étape 2, image 1 de 1
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
  3. BEM Mojo 2 Speaker Battery Replacement: étape 3, image 1 de 1
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
  4. BEM Mojo 2 Speaker Battery Replacement: étape 4, image 1 de 1
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
  5. BEM Mojo 2 Speaker Battery Replacement: étape 5, image 1 de 1
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
Rachel Iacoboni
Membre depuis le 01/30/18
618 Réputation
5 tutoriels rédigés
Équipe
Baylor, Team S1-G1, Johnson Spring 2018 Membre de l'équipe Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 520
