Introduction
Fix the distorted or unclear image in your Blu Life XL.
This guide instructs you on how to remove the back cover of the phone and replace the camera.
Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen. Remove the rear cover using your hands at the lip on the device back cover. No tools required. Remove the battery by lifting the lower edge of the battery up first.
  • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
  • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
  • Remove the battery by lifting the lower edge of the battery up first.
Ajouter un commentaire
Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver. Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Insert the plastic prying tool in between the plastic frame and the device. Keep the phone on the surface with its screen down.
  • Insert the plastic prying tool in between the plastic frame and the device.
  • Keep the phone on the surface with its screen down.
Use the plastic prying tool to gently push the rear camera out from its socket. Take the camera out and set it aside.
  • Use the plastic prying tool to gently push the rear camera out from its socket.
  • Take the camera out and set it aside.
Carefully place the new camera in the camera socket. Apply a little force on the top of the camera to slide it in the socket.
  • Carefully place the new camera in the camera socket.
  • Apply a little force on the top of the camera to slide it in the socket.
  • Pop the camera in the socket and make sure its stable.
Shantanu Malhotra
Membre depuis le 14/02/2018
172 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S2-G5, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 18
Total : 30
