Introduction
Having issues with your volume control buttons? This guide instructs you to detach the rear panel assembly in addition to the rear plate and replace the volume control buttons.
Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen. Remove the rear cover using your hands at the lip on the device back cover. No tools required. Remove the battery by lifting the lower edge of the battery up first.
  • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
  • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
  • Remove the battery by lifting the lower edge of the battery up first.
Ajouter un commentaire
Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver. Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Firmly press the prying tool into the gap between the front glass and rear plate.  This gap is located on all sides of the phone. Run the prying tool around the entire phone separating the rear plate from the frame.
  • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
  • Run the prying tool around the entire phone separating the rear plate from the frame.
Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery. Replace the component and reapply the tape over the buttons. Replace the component and reapply the tape over the buttons.
  • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
  • Replace the component and reapply the tape over the buttons.
James Whitlow
Membre depuis le 14/02/2018
330 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S2-G5, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 39
