Aller au contenu principal
BOSE SoundTouch 30 Display Assembly Replacement
Ce dont vous avez besoin
  1. BOSE SoundTouch 30 Display Assembly Replacement, Base Plate: étape 1, image 1 de 2 BOSE SoundTouch 30 Display Assembly Replacement, Base Plate: étape 1, image 2 de 2
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
  2. BOSE SoundTouch 30 Display Assembly Replacement, Display Assembly: étape 2, image 1 de 1
    • Remove the three 15.5mm PH2 screws holding the front-mesh grille in place.
  3. BOSE SoundTouch 30 Display Assembly Replacement: étape 3, image 1 de 1
    • Remove the grille by gripping the edges and pulling upwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
  4. BOSE SoundTouch 30 Display Assembly Replacement: étape 4, image 1 de 2 BOSE SoundTouch 30 Display Assembly Replacement: étape 4, image 2 de 2
    • Remove the six 8.9mm T9 torx screws holding the display assembly down.
    • The display assembly can now be lifted out of the grille so that a new one can be put in.
2 autres ont terminé cette réparation.
Brennen Irey
Membre depuis le 04/18/18
1 065 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S16-G2, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S16-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G2
4 membres
6 tutoriels rédigés
Un commentaire
Display assembly price
imrankhannnnn786 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 13
30 derniers jours : 57
Total : 3,720
