Aller au contenu principal
Basis B1 Band LED Screen Replacement
Ce dont vous avez besoin
  1. Basis B1 Band LED Screen Replacement, Watch Strap: étape 1, image 1 de 1
    • Wedge a plastic opening tool between band contacts.
  2. Basis B1 Band LED Screen Replacement: étape 2, image 1 de 1
    • Push in plastic opening tool until the components click and pop out of the holder.
    • Repeat steps for other band.
  3. Basis B1 Band LED Screen Replacement, Back Plate: étape 3, image 1 de 1
    • Remove four 4mm screws using a PH000 screwdriver.
    • Remove back plate.
  4. Basis B1 Band LED Screen Replacement, Battery: étape 4, image 1 de 1
    • Use tweezers to remove elastomeric, or zebra, connector.
  5. Basis B1 Band LED Screen Replacement: étape 5, image 1 de 2 Basis B1 Band LED Screen Replacement: étape 5, image 2 de 2
    • Use the flat end of the spudger to carefully lift the battery until adhesive seal is broken.
  6. Basis B1 Band LED Screen Replacement: étape 6, image 1 de 1
    • Use the pointy edge of the spudger tool to detach battery leads from the circuit board.
  7. Basis B1 Band LED Screen Replacement, LED Screen: étape 7, image 1 de 2 Basis B1 Band LED Screen Replacement, LED Screen: étape 7, image 2 de 2
    • Use PH000 screw driver to remove two 6mm bracketed screws.
    • Remove bracket.
  8. Basis B1 Band LED Screen Replacement: étape 8, image 1 de 1
    • Use PH000 tool to remove two 4mm screws.
  9. Basis B1 Band LED Screen Replacement: étape 9, image 1 de 1
  10. Basis B1 Band LED Screen Replacement: étape 10, image 1 de 1
    • Use spudger tool to lift the clasp of LED connector strip and remove from watch case.
  11. Basis B1 Band LED Screen Replacement: étape 11, image 1 de 1
    • Use spudger tool to remove the LED screen from the watch case.
Kaitlyn Lee
Membre depuis le 11/06/17
518 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S6-G1, Baechle Fall 2017 Membre de l'équipe IUPUI, Team S6-G1, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G1
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 200
