Introduction
Beats mixr have a very flexible headband that is made to bend in different ways. After time, the headband can weaken and break. Luckily, it is an easy fix.
Use a spudger or prying tool to remove the cap on both sides of the headband by applying pressure where the cap meets the band. Next, you will need a Phillips head #00 screwdriver to remove the screws and washer. Twist the screwdriver into the screw and pull it apart from the washer when it becomes loose.
  • Use a spudger or prying tool to remove the cap on both sides of the headband by applying pressure where the cap meets the band. Next, you will need a Phillips head #00 screwdriver to remove the screws and washer. Twist the screwdriver into the screw and pull it apart from the washer when it becomes loose.
Ajouter un commentaire
Begin by pulling the two parts of the headband away from each other slowly and make sure not to break any wires. The wires will now slide free of the headband.
  • Begin by pulling the two parts of the headband away from each other slowly and make sure not to break any wires. The wires will now slide free of the headband.
24 autre(s) ont terminé cette réparation.
Allie Horton
Membre depuis le 08/10/2014
794 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-11, Donnelly Fall 2014 Membre de l'équipe USF Tampa, Team 1-11, Donnelly Fall 2014
USFT-DONNELLY-F14S1G11
1 membre
2 tutoriels rédigés
Started to disassemble my Mixr. After removing the covers I found the screws not so easy to remove as stated. For one, they must have used lock tite. In addition the nut and screw are so tight a screw driver will not work. Mine has spanner type nuts. I need to find a wrench that will fit.
Has anyone ran into this.
Robert Schumann - Réponse
Did you figure out how to get the screws out without breaking?
simmons4jesus -
Voir les statistiques:
Dernières 24 heures : 8
7 derniers jours : 45
30 derniers jours : 176
Total : 10,238
