Aller au contenu principal
Beats Studio 2.0 Ear Pads Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Beats Studio 2.0 Ear Pads Replacement, Detach the old cushionDetach: étape 1, image 1 de 1
    • Grab a butter knife and start separating the cushion from the headphones. We must warn you not to use anything sharper than a butter knife, it can damage your headphones as well as have the potential for injury.
  2. Beats Studio 2.0 Ear Pads Replacement, Clean the remaining adhesive: étape 2, image 1 de 1
    • It is very important that you clean the remaining adhesive! If you have any remaining adhesive, there will be a weird gap in-between the headphones and the cushions. You can even use an alcohol wipe to remove the adhesive. The bottom line is, the cleaner the surface, the better the ear pads will stick!
  3. Beats Studio 2.0 Ear Pads Replacement, Grab your replacement right side cushion: étape 3, image 1 de 1
    • You will see that the right side cushion is the cushion with a gap where the USB port should be. These are not an ordinary cushions, they have an extremely strong and thick adhesive that is crucial for this process to work.
  4. Beats Studio 2.0 Ear Pads Replacement, Prepare the adhesive: étape 4, image 1 de 1
    • To make it easier for you to peel the adhesive, take a sharp knife and make a small cut on the surface. BEFORE you peel the adhesive, read the next step!
  5. Beats Studio 2.0 Ear Pads Replacement, Align the holes with dowels on the headphones: étape 5, image 1 de 1
    • There are two dowels on the headphone, on the top left and the bottom right. You can get a better understanding of how to apply the cushion to the headphones before peeling the adhesive.
  6. Beats Studio 2.0 Ear Pads Replacement, Peel the adhesive & attach the ear pads: étape 6, image 1 de 1
    • So take your ear pad and align the top dowel to the hole, push it in, and then align the bottom one. Apply pressure on the ear pads for a good minute that way you remove any gaps. If you have noticeable gaps, that means you have not aligned the cushion correctly and try again.
  7. Beats Studio 2.0 Ear Pads Replacement, Condition: étape 7, image 1 de 1
    • The last most important step! Apply constant pressure on the ear pads by taking a couple of books and putting the headphones on them in a way that applies the most pressure without bending the headphone headband to far. We hope you enjoyed this simple tutorial, if you have any questions, do not hesitate to contact us.
To replace your cushions , please follow the next steps .
11 autres ont terminé cette réparation.
Wicked Cushions
Membre depuis le 03/31/17
301 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 23
7 derniers jours : 129
30 derniers jours : 698
Total : 91,491
