Introduction
A failed impulse coupling can cause the crankshaft gear to break off. This will cause the aircraft's magneto not to work therefore the aircraft's engine will not start.
Pièces
Aucune pièce nécessaire.
Use a 9/16 wrench to unscrew the nut on the drive shaft. Use a 9/16 wrench to unscrew the nut on the drive shaft.
  • Use a 9/16 wrench to unscrew the nut on the drive shaft.
Ajouter un commentaire
Remove the lock washer underneath the nut.
  • Remove the lock washer underneath the nut.
Pull away the impulse coupling. Pull away the impulse coupling.
  • Pull away the impulse coupling.
Kelsi English
Membre depuis le 26/09/2012
381 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 1-2, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 1-2, Propen Fall 2012
CPSU-PROPEN-F12S1G2
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 17
Total : 3,317
