Aller au contenu principal
Besta Super 5000 Back Cover Replacement
Ce dont vous avez besoin
  1. Besta Super 5000 Back Cover Replacement, Battery: étape 1, image 1 de 1
    • Turn the device over so that the barcode is facing upwards.
  2. Besta Super 5000 Back Cover Replacement: étape 2, image 1 de 2 Besta Super 5000 Back Cover Replacement: étape 2, image 2 de 2
    • Place your fingers on the battery cover arrow and pull the cover down and off the device.
  3. Besta Super 5000 Back Cover Replacement: étape 3, image 1 de 1
    • Pull upwards on the battery tab to remove the battery from the device.
  4. Besta Super 5000 Back Cover Replacement, Back Cover: étape 4, image 1 de 1
    • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
  5. Besta Super 5000 Back Cover Replacement: étape 5, image 1 de 1
    • Remove the two screws behind the battery using a Phillips #0 screwdriver.
  6. Besta Super 5000 Back Cover Replacement: étape 6, image 1 de 2 Besta Super 5000 Back Cover Replacement: étape 6, image 2 de 2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
    • Gently pry off the backing using an opening tool.
Jessie
Membre depuis le 09/30/14
370 Réputation
3 tutoriels rédigés
Équipe
Ohio State, Team 1-5, Buehl Fall 2014 Membre de l'équipe Ohio State, Team 1-5, Buehl Fall 2014
OSU-BUEHL-F14S1G5
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 279
