Aller au contenu principal
Besta Super 5000 Keyboard Replacement
Ce dont vous avez besoin
  1. Besta Super 5000 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Turn the device over so that the barcode is facing upwards.
  2. Besta Super 5000 Keyboard Replacement: étape 2, image 1 de 2 Besta Super 5000 Keyboard Replacement: étape 2, image 2 de 2
    • Place your fingers on the battery cover arrow and pull the cover down and off the device.
  3. Besta Super 5000 Keyboard Replacement: étape 3, image 1 de 1
    • Pull upwards on the battery tab to remove the battery from the device.
  4. Besta Super 5000 Keyboard Replacement, Back Cover: étape 4, image 1 de 1
    • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
  5. Besta Super 5000 Keyboard Replacement: étape 5, image 1 de 1
    • Remove the two screws behind the battery using a Phillips #0 screwdriver.
  6. Besta Super 5000 Keyboard Replacement: étape 6, image 1 de 2 Besta Super 5000 Keyboard Replacement: étape 6, image 2 de 2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
    • Gently pry off the backing using an opening tool.
  7. Besta Super 5000 Keyboard Replacement, Motherboard: étape 7, image 1 de 1
    • Remove the three silver screws from the black round battery using a Phillips #0 screwdriver.
  8. Besta Super 5000 Keyboard Replacement: étape 8, image 1 de 1
    • Remove the five small screws from the motherboard using a Phillips #0 screwdriver.
  9. Besta Super 5000 Keyboard Replacement: étape 9, image 1 de 3 Besta Super 5000 Keyboard Replacement: étape 9, image 2 de 3 Besta Super 5000 Keyboard Replacement: étape 9, image 3 de 3
    • Using a pair of tweezers, pinch the center of the yellow ribbon located in the corner of the device.
    • Potential for device damage: Do not yank or remove the ribbon from the device.
    • Carefully pull the hidden piece of yellow ribbon out from underneath the motherboard.
  10. Besta Super 5000 Keyboard Replacement: étape 10, image 1 de 2 Besta Super 5000 Keyboard Replacement: étape 10, image 2 de 2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the motherboard with screws still in it because you may damage it.
    • Carefully pry off the motherboard with an opening tool.
  11. Besta Super 5000 Keyboard Replacement: étape 11, image 1 de 1
    • Take the motherboard out of the body frame.
  12. Besta Super 5000 Keyboard Replacement: étape 12, image 1 de 2 Besta Super 5000 Keyboard Replacement: étape 12, image 2 de 2
    • Lift the black keyboard mat off of the motherboard.
    • Replace the motherboard.
  13. Besta Super 5000 Keyboard Replacement, Keyboard: étape 13, image 1 de 1
    • Replace the old keyboard mat with a new keyboard mat.
Sarah
Membre depuis le 09/30/14
138 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 1-5, Buehl Fall 2014 Membre de l'équipe Ohio State, Team 1-5, Buehl Fall 2014
OSU-BUEHL-F14S1G5
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 4
Total : 227
