Introduction
When you press the retract button on the front of the vacuum, does the power cord not move? If so, here is the guide to replace the entire cord and reel.
Grab hold of both the flex hose handle  and the extension wand. Pull straight out to detach the handle from the extension wand.
  • Grab hold of both the flex hose handle and the extension wand.
  • Pull straight out to detach the handle from the extension wand.
Ajouter un commentaire
Locate the lock clip on the other end of the flex hose.
  • Locate the lock clip on the other end of the flex hose.
- color code this step to match the red indicator
-watch out for the lighting (hard shadows)
Austin Marshall - Réponse
Hold down the lock clip to unlock the flex hose from the vacuum. Remove the flex hose from the vacuum.
  • Hold down the lock clip to unlock the flex hose from the vacuum.
  • Remove the flex hose from the vacuum.
After removing hose, place vacuum on back and unclip the top compartment. Open the compartment. Pull the dirt collection box out of the vacuum.
  • After removing hose, place vacuum on back and unclip the top compartment.
  • Open the compartment.
  • Pull the dirt collection box out of the vacuum.
Place dirt collection box to the side. Locate the Pre-Motor Filter. Pull the filter out by grabbing the pull tab on top.
  • Place dirt collection box to the side.
  • Locate the Pre-Motor Filter.
  • Pull the filter out by grabbing the pull tab on top.
Turn vacuum around and locate the filter cover on the bottom. Place fingers in the opening and pull off the filter cover. Place fingers on each tab on the Post-Motor HEPA Media Filter and pull out.
  • Turn vacuum around and locate the filter cover on the bottom.
  • Place fingers in the opening and pull off the filter cover.
  • Place fingers on each tab on the Post-Motor HEPA Media Filter and pull out.
Take filter out to clean or replace. To clean Dirt Collection Box, unlatch lid and take off. To clean Dirt Collection Box, unlatch lid and take off.
  • Take filter out to clean or replace.
  • To clean Dirt Collection Box, unlatch lid and take off.
Flip Dirt Collection Box over and locate the push tab. Push the Dirt Cup HEPA Media Filter up to take it off. Picture 3 Shows all the filters taken out of the vacuum.
  • Flip Dirt Collection Box over and locate the push tab.
  • Push the Dirt Cup HEPA Media Filter up to take it off.
  • Picture 3 Shows all the filters taken out of the vacuum.
Unscrew the two screws underneath the dirt collection box inside the vacuum. Unscrew the two screws underneath the dirt collection box inside the vacuum.
  • Unscrew the two screws underneath the dirt collection box inside the vacuum.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Flip over vacuum.
  • Flip over vacuum.
Unscrew both screws on the bottom of the handle. Unscrew both screws on the bottom of the handle.
  • Unscrew both screws on the bottom of the handle.
- dark lighting (black screw against black medium)
Unscrew both screws near the wheels. Unscrew both screws near the wheels.
  • Unscrew both screws near the wheels.
- missing period
Flip over vacuum. Gently lift off top. Do not try to take off completely. There are still wires attached to the hull.
  • Flip over vacuum.
  • Gently lift off top.
  • Do not try to take off completely. There are still wires attached to the hull.
- keep extra items out of frame
- missing period
Locate the circuit board. Locate the circuit board.
  • Locate the circuit board.
- missing period
Unplug each orange plug. Make sure you remember which orange plug goes where! Make sure you remember which orange plug goes where!
  • Unplug each orange plug.
  • Make sure you remember which orange plug goes where!
- missing period
Unplug the red wires. The wires may be a little difficult to take off. If they are, you may use a pair of pliers to pull the wires off. Make sure not to wiggle the wires, as that may break the metal holding them.
  • Unplug the red wires. The wires may be a little difficult to take off. If they are, you may use a pair of pliers to pull the wires off.
  • Make sure not to wiggle the wires, as that may break the metal holding them.
Remove the top.
  • Remove the top.
Unscrew the top two screws on the vacuum. Unscrew the top two screws on the vacuum.
  • Unscrew the top two screws on the vacuum.
- missing period
-add indicator
- hard shadows
Unscrew the back two scews. Unscrew the back two scews.
  • Unscrew the back two scews.
- blurry image
- hard shadows
-indicators
- black screwdriver against black medium
Lift motor and move it over the gain access to the spool. Unscrew the screw on the spool. Remove the plastic circle.
  • Lift motor and move it over the gain access to the spool.
  • Unscrew the screw on the spool.
  • Remove the plastic circle.
- missing period
- 2nd picture excess?
Remove the motor.
  • Remove the motor.
  • And you are done!
- you are not done after completion of this step.
Grab hold of the cord reel and cord. Make sure cord is retracted all the way in.
  • Grab hold of the cord reel and cord. Make sure cord is retracted all the way in.
Pull on cord reel to remove it. You should hear a click indicating it has detached from the area indicated in the picture.
  • Pull on cord reel to remove it. You should hear a click indicating it has detached from the area indicated in the picture.
- color code indicator steps
Use screwdriver to remove screws from either side of the cord. Use screwdriver to remove screws from either side of the cord.
  • Use screwdriver to remove screws from either side of the cord.
Flip over vacuum. Remove grate that holds the power cord as pictured.
  • Flip over vacuum.
  • Remove grate that holds the power cord as pictured.
Grab hold of head of power cord and pull up. Power cord should disconnect from vacuum body as pictured.
  • Grab hold of head of power cord and pull up.
  • Power cord should disconnect from vacuum body as pictured.
Remove the cord reel and cord from the vacuum body.
  • Remove the cord reel and cord from the vacuum body.
Rianne Paracuelles
Membre depuis le 18/01/2018
163 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S12-G1, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S12-G1, Banghart Winter 2018
CPSU-BANGHART-W18S12G1
5 membres
5 tutoriels rédigés
- very good guide
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 52
