Aller au contenu principal
Black and Decker BL3000S Motor Fan Replacement
Ce dont vous avez besoin
  1. Black and Decker BL3000S Motor Fan Replacement, Blender Base: étape 1, image 1 de 2 Black and Decker BL3000S Motor Fan Replacement, Blender Base: étape 1, image 2 de 2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Black and Decker BL3000S Motor Fan Replacement: étape 2, image 1 de 1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Black and Decker BL3000S Motor Fan Replacement: étape 3, image 1 de 2 Black and Decker BL3000S Motor Fan Replacement: étape 3, image 2 de 2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Black and Decker BL3000S Motor Fan Replacement: étape 4, image 1 de 1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Black and Decker BL3000S Motor Fan Replacement: étape 5, image 1 de 1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Black and Decker BL3000S Motor Fan Replacement, Motor Fan: étape 6, image 1 de 2 Black and Decker BL3000S Motor Fan Replacement, Motor Fan: étape 6, image 2 de 2
    • Using pliers, remove the top nut from the fan and remove the washer.
    • Use a small towel to hold the fan in place. This makes taking off the nut easier to do.
  7. Black and Decker BL3000S Motor Fan Replacement: étape 7, image 1 de 1
    • Lift the fan blades from the blender base.
3 autres ont terminé cette réparation.
Andrew
Membre depuis le 10/04/12
209 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 6-34, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
4 membres
6 tutoriels rédigés
Un commentaire
mon mixeur a montre des itincelles et de la fumeé quel étape puis suivre pour le réparer
abdelkarim hassi - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 35
Total : 4,412
