Introduction
If your drill stops working and the battery stops holding a charge chances are you need a new battery. You can find a replacement parts including the battery under the replacement part links in the device page. This guide will show you how to install this new battery.
Pièces
Aucune pièce nécessaire.
Remove the nine 15mm Philips #1 screws Remove the two 12.5mm Philips #1 screws Remove the two 10mm Philips #1 screws
  • Remove the nine 15mm Philips #1 screws
  • Remove the two 12.5mm Philips #1 screws
  • Remove the two 10mm Philips #1 screws
Ajouter un commentaire
Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
  • Lift one side of the drill casing off of the drill. Note that the drill casing consists of two pieces on either side of the drill.
Locate the battery and remove it from its slot at the end of the drill opposite the motor. It should be at the butt of the drill by the handle.
  • Locate the battery and remove it from its slot at the end of the drill opposite the motor. It should be at the butt of the drill by the handle.
what kind of batteries can I use to replace them
K3Ls - Réponse
I don't know what type of batteries are used in this drill, but you can buy them by clicking on the link entitled Black and Decker Pivot Plus PD600 Replacement Parts on the main page, or by using the below
http://www.ereplacementparts.com/black-a...
Jonathon Centofranchi - Réponse
Unplug the battery by pulling out both the red and black wires. They should come out easily with a little bit of force.
  • Unplug the battery by pulling out both the red and black wires. They should come out easily with a little bit of force.
  • But be careful not to disconnect the wire from the metal it is attached to. In order to avoid this, pull the wire out by holding on to the metal part instead of just the wire.
Now take the replacement battery and slide the metal parts of the wire into the metal part of the battery.
  • Now take the replacement battery and slide the metal parts of the wire into the metal part of the battery.
  • Make sure that the red wire connects to the curved end of the battery, and that the black wire connects to the straight end of the battery.
It's possible to email me the battery and battery charger specifications
Saeed.eslamikia43754@gmail. Com
Saeed - Réponse
6 autre(s) ont terminé cette réparation.
Membre depuis le 19/04/2013
219 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 4-15, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 4-15, Maness Spring 2013
CPSU-MANESS-S13S4G15
5 membres
6 tutoriels rédigés
this drill adapter, why "6V" and the adapter body is marked 9VAC output? which is true output?
Can someone test the output and tell me the voltage? VDC? VAC? thankyou.
u411323 - Réponse
Unfortunately I do not own the drill anymore so I can't test its output. I do know that the battery used is 6V, so I would assume that is the output. Hopes this helps!
Where can I buy the replacement battery pack for less than replacing the tool?
shgarceau - Réponse
Well, I just checked B & D's web site and can buy a battery pack for $17.95 PLUS $10.99 shipping (cheapest offered).
I think buying a new one is a better idea.
shgarceau - Réponse
Saeed - Réponse
Voir les statistiques:
Dernières 24 heures : 7
7 derniers jours : 40
30 derniers jours : 182
Total : 16,268
